Question on swap
Old Jan 23, 2007 | 12:59 PM
PWR-TRIP's Avatar
Question on swap
I have a 95 Z28 and i might be getting a 99 LS1 engine for a good price with low miles off course. Can i use the same T56 tranny? And is the LS1 swap possible in an LT1?
Old Jan 23, 2007 | 01:15 PM
reamo04's Avatar
i know a LS1 swap is possible into a LT1 car as I have seen them done before, but I do not know what you have to do.
IDK about the transmissions, i know w/ the 4l60Es, one has a longer input shaft so they are not interchangeable
Old Jan 23, 2007 | 05:49 PM
Bayer-Z28's Avatar
Going to have to change the bell housings on the tranny and *maybe* switch the braided clutch lines... Don't quote me on that last one.
SHouldn't be too hard. Basically the same car, just slightly different front end.
Old Jan 23, 2007 | 06:13 PM
ulakovic22's Avatar
The LS1 will not bolt up to a LT1 T56. You have to get the LS1 bellhousing and convert over to a LS1 T56 front adapter plate as well as run the pusher clutch system the LS1 uses. You can run a spacer on the end of the LT1 input shaft, but I wouldn't recommend that ever. Would be easier to just sell your LT1/T56 combo and get a LS1/T56 combo together. It will slide right in no problems with the LS1 engine wiring harness.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
chuyz28
Feb 19, 2015 12:50 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
