question on quick disconnect (getting frustrated)
Old Aug 11, 2008 | 11:10 AM
GSS9909's Avatar
For some reason I can not get the quick disconnect to stay in the slave cylinder. every time I press the clutch in it pops out just enough to disconnect.
I undid the bleeder valve to let out pressure and then connected it. Still did not work. It will bleed when the bleeder is open, but when
I tighten it up. POP goes the braided line right out of the slave.
can some one on here please help me.
Old Aug 11, 2008 | 02:12 PM
blackbirdta's Avatar
this may be a stupid answer, but did you put the pin in?
Old Aug 11, 2008 | 03:57 PM
GSS9909's Avatar
I don't think there is a pin that holds it just some metal ring with some teeth on it. But if there is a pin that would be why.
I never saw a pin.
thanks for repling and trying to help. I had posted this question before and no one answerd. thanks again
Old Aug 12, 2008 | 06:58 AM
I just noticed you mentioned a bleeder valve so you probably have an ls1 right? The lt1 has no bleeder valve, but it does have a pin that goes through to attach the slave. does the slave have a little hole that goes through where the hose attaches? I'm not sure the ls1 and lt1 are the same as far as that goes...
Old Aug 13, 2008 | 10:38 AM
GSS9909's Avatar
Yes it is a ls1 and no there is no hole in the sleeve to the slave.
Damn why is it so hard to get this stupid thing to lock in?
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
