Question about shift kit
Old Feb 19, 2006 | 04:32 PM
nodnarb481's Avatar
I test drove a trans am with a bunch of mods one of which was a shift kit. the 1-2 Shift was very rough almost like hitting a pot hole but then the other shifts were very nice. The owner said it was how he had it customized for the 1-2 shift to be perfect at WOT. I never got to try WOT but just driving it was a pretty rough shift. I believe him 100% but i have no knowledge of shift kits and was wondering if this is a common thing?
Old Feb 19, 2006 | 04:41 PM
Firehawk0194's Avatar
Re: Question about shift kit
I have a tranco shift kit and my 1-2 shift is very smooth. I also have it tuned and the shift firmness is higher than normal. I do have a TCI 3,000 Stall which takes away from some of the jerkyness. Not sure if that helped any, but I would be a little concerned that something isnt right if its shifting that hard in the 1/2.
Old Feb 19, 2006 | 05:04 PM
nodnarb481's Avatar
Well he said that it is custom set to shift really good and on the money at WOT and that in turn makes it a little rough when you are just casually driving. I dont know anything about this stuff so I am trying to get as much information as I can because I have enough to buy the car but not fix a transmission too
Old Feb 19, 2006 | 11:09 PM
Pro Built Automatics's Avatar
You can have the WOT shift just the way you want, and the part throttle shifts the way you want also, it does not have to be one or the other.
Old Feb 20, 2006 | 12:01 PM
nodnarb481's Avatar
well all i know is that i never tested it at WOT but the harder you were on the gas the less violent the shift was
Old Feb 20, 2006 | 01:45 PM
MyShibbyZ28's Avatar
I would be cautious, I think that hard shift is a warning. If it is a shift kit, than it shouldn't be shifting hard on part throttle shifts all the time. If it was tuned, you can have it tuned to just WOT or just part throttle, since the computer puts in a different table of shift firmness at WOT. Personally I would want to see proof of the shift kit or tune. Also, test it at WOT, it should be firm, but not jerk the car or be hard.
Old Feb 20, 2006 | 09:18 PM
nodnarb481's Avatar
it is tuned to WOT
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
