question about A4 to M6 swap
Old Aug 27, 2005 | 07:46 PM
Blackout96's Avatar
Hey guys...we just got done doing a A4 to M6 swap...did anybody have a problem using their original drive shaft? I've been told we could use the original drive shaft and we tried...when we slide it into the end of the tranny, it goes in about an inch then stops...is this normal?...the car is a 94 Z28 and the M6 tranny came out of a 94 Z28 also.....
anybody have any input on this?..thanks
Old Aug 27, 2005 | 08:25 PM
rngilliland's Avatar
Re: question about A4 to M6 swap
I don't know why you are having a problem but the original driveshaft should work fine. I swapped to a M6 on my 94 and used the original driveshaft.
Old Aug 27, 2005 | 10:13 PM
Janny's Avatar
I've been using mine for the last 3 years. No problems.
Old Aug 28, 2005 | 01:06 AM
Blackout96's Avatar
i dunno then...it slides on about an inch then then stops....
Old Aug 29, 2005 | 04:32 AM
97pontta's Avatar
Are the splines damaged on the output shaft of the tranny? The drive shaft should slip in the tranny at least 4 inches.
Old Aug 29, 2005 | 04:45 AM
Blackout96's Avatar
i'm not sure...i'm going to be checking it out when i get doen at work here in a few hours...i hope they aren't
Old Aug 29, 2005 | 08:45 AM
Blackout96's Avatar
Ok...i took the rear seal off the tranny and i noticed what the drive shaft has been hitting....inside the tranny housing there is some type of sleeve with holes and slots in it...it is probably only about 1/16-1/8 thick...it looks like it might be in there to prevent play between the drive shaft and the housing..is that sleeve mandatory to have in there or can it be removed....it's probably only about an 1"-1.5" long.....can anybody tell me what this sleeve is and if i need it..thanks
Josh
Old Aug 29, 2005 | 01:53 PM
I wouldn't remove the bushing. I belive it is there to help support the output shaft. If your driveshaft yoke won't fit then you need to find out why and correct it. It takes a little wiggling to get mine in. You might try another driveshaft if you have access to one. If your trans and driveshaft are from 4th generation f bodies it should fit with no problems unless something is damaged. You might be able to get a yoke at a parts house or the dealer. Try it and if it works you would know you have a problem with yours. If it doesn't you could return it.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
chuyz28
Feb 19, 2015 12:50 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
