Pwm?
Old Jun 29, 2010 | 12:48 PM
Wart Hog's Avatar
Pwm?
I just pulled the transmission out of my 95 Z and the front pump doesn't have PWM on it. It has the numbers "8681704"
Anyone have a clue what this is and what is a PWM pump?
Also the side of the transmission has the numbers 8680514. Is this a 4L60E for a 95 Z?
Old Jun 29, 2010 | 01:17 PM
bobdec's Avatar
the '95 and up used Pulse With Modulation (PWM) to control Torque Converter Lockup called TCC PWM. The TCC PWM solenoid does not exist in 'the '94 and below. Also if you have a '95 PCM code with a '94 4L60E then someone probably added a resistor to dummy up the PWM solenoid or changed PCM code to '94 code to get rid of the PWM DTC error.
From what I see it's a '94 tranny, no PWM, this may help you prove it, ref shoebox.. http://shbox.com/1/block_vin.jpg
Also this http://mmerlinn.com/catalog/lilscrib...6/gm9l6010.htm
4L60-E, Rwd
Case = 8680514, Chevy, No NSS bosses, No linkage lugs
Tail = 8673553
Valve body = 8678393, 5 solenoids [ ]
Cheese plate = KT
Pump body = 8682132, Not PWM
Stator support = 8681612
Input pilot
sswagon
Sep 22, 2021 12:00 AM
Performabuilt
Jul 23, 2019 09:02 PM
mvvette97
May 3, 2009 09:13 PM
asudecat
Sep 20, 2006 02:21 PM
MysticTeal 95 V6
Feb 18, 2003 12:16 PM
