Pullin Transmission
Old Dec 8, 2007 | 10:04 PM
theratdude64's Avatar
Pullin Transmission
My Trans went out on the 95Z *4L60E* and its being quite the beast to pull. I've pulled transmissions before, but this sucks.
Anyone happen to know what bolt size? Metric/standard? And How many? 6? I can't see schitt up there between my exhaust, wires,dipstick tube, ect being in the way
edit: yep, 6 bolts. Finally found a decent pic
Old Dec 8, 2007 | 11:45 PM
Green96Z's Avatar
I think they are standard, but can't remember. The hardest one for me to get was the driver side second from the bottom, the tranny tunnel was getting in the way. The top ones you have to get with some long extensions from the back. Once you get all six bolts off (make sure the torque converter is unbolted too) then back it off the dowel pins and drop it down so you can get the cooler lines off.
Old Dec 9, 2007 | 12:02 AM
Yeah I've got a combined total of like 6 feet of extensions around her :lol2:
The drivers side is the beast for me too No way of gettin in there it seems. The wire harness seems to be fastened down RIGHT by the bolt so Its a beast to move it enough to the socket on there.
Old Dec 10, 2007 | 12:02 PM
northdakota93z28's Avatar
i did not use a socket i used a open end, you could only move it a little at a time, it sux but i got it(i could not fit socket on) and just got my new tranny in about 20 mins ago!!
Old Dec 10, 2007 | 01:51 PM
Green96Z's Avatar
Actually, I think that's how I ended up getting that bolt off. I got it back on by using one of those flex sockets after a lot of pounding and yelling at the car . I would put the bolt through the tranny BEFORE you mount it on the guide pins. That way you don't have to worry about getting it back in the hole, just tightening it down.
Old Dec 10, 2007 | 03:06 PM
wait, which bolt you talkin about? And what size I'm having a beast of a time figuring out which size it is because I can't get my arms up in there. But then again, I've only attacked the passenger side so far because its up near a wall on the drivers and I'm dreading goin over there haha. But I spose I gotta
Old Dec 10, 2007 | 04:58 PM
9/16 thats what the tranny bolts are there are 6, that is the only hard one just get long extensoins and a swivel and you will get it. by the end i hated life but i got it.
Old Dec 10, 2007 | 05:01 PM
Yep, got some done just now
Just now went and undid the torque converter, undid the mounts and supporting it by the back of it, and got a Bellhousing bolt out so far. Not lookin forward to the passenger side at all. I can't even see the top ones I only see like 3-4 of em besides the one I got
Old Dec 10, 2007 | 05:16 PM
Green96Z's Avatar
The passenger side should be easy. The bottom one all you need is a swivel extension. For the other two, use long extensions and get them from behind the tailhousing of the tranny. Flash a light down there to see them. As long as the tranny is dropped far enough you should be able to see them and get them pretty easily. You might have to move part of the wire harness to get one.
Driver side is the PITA. Bottom one again is easy. Top one is the same as the passenger top, long extensions do it. The middle one is the hard one to get. I loosened it with a box end, took me like 10 minutes to get it out. If you are having trouble breaking them loose, use a cheater bar (a pipe that will slide over the handle of your ratchet) or a breaker bar.
Old Dec 10, 2007 | 05:30 PM
The Middle drivers side? That one doesnt seem like its hard to get to. Hrmm.
The dipstick/harness are in the way of the passenger side ones. I havent taken a good luck at it since i lowered the trans down, but just lowering it to about where it wants to hang is good right? Don't gotta undo anything else to make it lower? I have it supported just above where it wants to naturally hang down.
Old Dec 10, 2007 | 05:44 PM
mdacton's Avatar
put the jack under and cut the cross member loose and lower it a little it will make it easy to get to
Old Dec 10, 2007 | 10:08 PM
showstoppers-96-Z/28's Avatar
Exactly, dont literally cut your cross member, simply unbolt it with your jack under your trans slightly supporting it. This will let your trans "slouch" downward and give you an easier view of the bolts and such. Before you take all of your bell housing bolts out, be sure that your torque converter bolts are taken out (if you have not already done so). Keep the extension lengths to a minimum, the further you get away from that ratchet/air tool, the more torque you sacrifice. Dont quote me on this but i THINK the bell housing bolt heads are 14mm, if they are not, they're more than likely 9/16. Take your time, DO NOT lose your patience!! once your trans is all unbolted and secured/balanced on the jack, lower it down VERY CAREFULLY AND SLOWLY. Stop it at an optimum point for you to take loose your wiring harness to the side of it, and your cooler lines. Remember to flush your cooler completely before you fill the new trans will fluid, any old trash in that cooler will go right back into a nice new clean trans and make nice new problems . Again, you've done this before, its not too bad, just take your time, dont give up and dont get too frustrated.
Old Dec 10, 2007 | 10:28 PM
Nice, thanks for all the help Yeah, 9/16ths fits, but 14mm seems to fit better. Taking the TC bolts off was a breeze, I was dreading needing to turn the engine with a flywheel turner or something... but I could just grab the Flywheel and spin it by hand while down there. Real simple. I have it hanging down with a jack stand under the end of it thats holding it like 1/2 inch or so above where it wants to hang fully down. So its supported but down there. I got the Bottom drivers bolt out so far, gonna attack the rest tomorrow. I'm hoping to do aftermarket trans cooler when I go back in, is there much advantage over the stock one? My truck has a cooler mounted in front of radiator and I really like it.
:edit: With the real long extensions, do ya use a swivel with them? or can you get a good angle without it? I dont like usin the Swivels blindly, too much of a pain to maneuver them up there. Sounds like Just swivel on the passenger side middle/bottom? Or did I read that wrong
Old Dec 11, 2007 | 05:38 PM
Mission Accomplished! Those top bolts were a LOT easier than I thought
Thanks for all the help guys
Old Dec 12, 2007 | 06:09 PM
PoorMan's Avatar
Pics of rear intake leak?
