problems with rear?
Old May 14, 2008 | 08:45 PM
mikemassi's Avatar
problems with rear?
hi, i have a 94 Z28 with 90,000 miles. it seems that everytime i floor it the back rear left tire seems to like thump like its hitting a pot hole. it also does it wen it shifts into second. anyone know what this could be?
Old May 14, 2008 | 09:35 PM
DelSoto's Avatar
You sure it is coming from that far back? Sounds like the trans mount has broken.
Old May 14, 2008 | 11:02 PM
mikemassi's Avatar
well it feels like it the back, but i can feel it vibrate in the middle where the shifter is also. Even wen i get on it tho, it still chirps second and performs fine.
Old May 15, 2008 | 12:12 AM
bombebomb's Avatar
May be tranny mount.
Old May 15, 2008 | 12:24 AM
derekderek's Avatar
My torque arm came loose once and made a similiar sound. But sounds like a tranny mount. If the shifter is moving to it's not wheel hop is it?
Old May 15, 2008 | 02:54 AM
SS RRR's Avatar
The first thing I would check is the LCA's for excessive play. A bushing in the LCA could've failed.
Old May 15, 2008 | 07:33 AM
Airbornec507's Avatar
Make sure the pinion bolt is tight too. You'l have to take the Drive Shaft out to check it.
Old May 17, 2008 | 09:48 AM
stvski80085's Avatar
My 95 z28 was doing the same thing. After investigation I found the rear sway bar was hitting an aftermerket differential plate. I am replacing the whole rear end so I'm just letting it be for now but I would check it out.
jcamaro95lt1
Jan 24, 2015 08:21 AM
Rod Bender
Jan 1, 2015 03:18 PM
siguy
Nov 27, 2014 10:07 AM
slothgrant
Aug 22, 2002 03:01 PM
