Prevent fishtailing on launch
Old Jan 2, 2005 | 12:48 AM
pHEnomIC's Avatar
When i floor my car off a stop, it feel like my rear end goes side to side. Is there any way to prevent this, i have trouble in the rain when i dont floor it, this happens as well.
Old Jan 2, 2005 | 07:14 PM
OBE1 95Z28's Avatar
Re: Prevent fishtailing on launch
Verify that your posi system is still functional; do you generate both tire marks when you stomp on the gas?
Old Jan 2, 2005 | 11:14 PM
pHEnomIC's Avatar
I only make 1 mark, so i think its working
Old Jan 2, 2005 | 11:28 PM
n20ta2's Avatar
Most likely if you see only one mark its not working correctly.This could be the cause of your fish tailing prob.
Old Jan 2, 2005 | 11:51 PM
A working posi lays down two strips of rubber.... and will generally only move the car to one side when the tires break loose. "Fishtailing" would indicate a faulty posi and/or some suspension problem.
Old Jan 3, 2005 | 11:24 PM
1BAD86Z's Avatar
also see if your endlinks are tight on the rear swaybar. also check on the bushings on the axle that hold the swaybar. but i've seen bent panhard bars act the same way. has the car been in an accident?
Old Jan 3, 2005 | 11:43 PM
"White Knight"'s Avatar
yea one mark means she's gone. My car does it and has a good posi, mine is most likely due to the LCA's being adjustable and i haven't adjusted them yet---i mean they are close, but a little bit goes a long way--difference between straight and not straight. I garentee it's your posi......at the track when my posi was gone.....i'd be heading for the guardrail everytime i did a burnt out in the box.
Old Jan 4, 2005 | 12:55 AM
pHEnomIC's Avatar
I could be wrong, i never really pay much attention to my marks. My friend told me once that i laid one mark. Ill check in a parking lot in a few days so 2 tire marks is good then? Ill make sure everythings tight in back. The side to side could be normal, im not sure if im just imagining it but there is some.
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 7, 2015 08:52 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
Jul 17, 2015 02:47 PM
mark0006
Dec 25, 2014 09:50 PM
