Power program?
Re: Power program?
You can buy a Hypertech Power Programmer. Used is the best deal, because a new one is over-priced, and the "power program" is virtually worthless. But it is convenient for shift point changes, rev limiter adjustment, rear axle changes, speed limiter removal, fan on/off temps. You have to make sure the original owner returned his PCM to stock using the programmer, or it won't work with your PCM (although there is a way around that).
Alternatively, you can send your PCM to a mail order tuner, and he can set it up any way you want.
carguyshu
Jan 22, 2017 11:19 AM
94z28jbw
Sep 8, 2002 03:22 PM
