Power loss through a 9"?
Hey guys, I'm going with a 9" ford for brute strength, however I do know they aren't the most efficient rear ends available. What kind of power loss (parasitic) can I expect going from a 10 bolt with 4.10's to a 9" with 4.10's? Thanks guys!
Re: Power loss through a 9"?
The numbers I've seen published in a tech article in National Dragster indicated the losses were:
Dana 60 - 5%
GM 12-bolt - 7%
Ford 9-inch - 10%
I would assume the 10-bolt is close to the 12-bolt, since the relationship of the pinion shaft centerline to the axle centerline is similar. So, you could expect to see a 3% drop in rwHP. In a 500HP setup, that would cost you 15HP, which is about 0.10-second and 1.1 MPH.
Dana 60 - 5%
GM 12-bolt - 7%
Ford 9-inch - 10%
lol hi scott! I'll call you later today, thanks for all your help with this. I babied the car back to my apartment, I'm sure I can at least drive it on to a trailer, I hope....
yeah that was just and example...he also swapped to a TH-350 around that time so we were still trying to figure out what killed us more. Only reason we think it was the rear is we lost weight on the trans swap but gained significantly on the rear. Car still hooks like a son of a gun. Just things to figure out.
Chris
Chris
Chris
Chris
yeah so that's probably where his et trouble came from, but I don't think he was thinking it would hurt him that much. He dropped half a second and it suprised the snot out of all of us...everyone was looking for other issues, then he decided to tell us the car runs really fat on the top end, and TPIS can't even lean it out right for him...loads of fun.
Chris
Chris
Hey MIke, i finished your 9" center and i got some pics, but i can not post here so hit MM and i'll post them up.
email them to me! Mike94ZLT1@yahoo.com. I'm gonna order the BMR stuff right now. Thanks scott!
