Posi may be dying, cheap options?
Ok, I've got a 97 A4 Z-28, and had the stock 2.73 gears changed out for 3.73 Richmonds (mechanic used Redline synthetic gear oil.) Car was a one-legger before AND after the change. It has 60K miles on it.
I just ordered some Nitto 555-r's to help out once I get the diff working, but here's where I'm screwed: I can't afford a $400 diff and install right now, so Eatons and the like are out. I have a few questions:
If I get a new carrier (hopefully the right 2.73 carrier so I can use my new gears) will the gears have to be totally reinstalled again? Or just use the same number of shims on each side and go?
Also, can I buy a used diff or is there a cheap (stock type) replacement I could use instead of an Eaton?
I just don't want to have to pay $300 for labor and $400 for a carrier so I can make the stock crappy 10 bolt work. Use is 95% street, 5% strip.
Thanks guys,
Chris
Thanks guys,
Chris
Re: Posi may be dying, cheap options?
Just order one from one of the f-body salvage yards or find one from a junkyard. New posis are really hard to find cheap.
With a different carrier you'll have to ensure pinion depth and backlash are correct. It shouldn't be too far off, and it's not really that hard to adjust.
Victor Lamb
Aug 26, 2017 02:52 PM
