popping around right turns
Old Sep 27, 2003 | 12:08 PM
2000zee28's Avatar
My M6 z28 has a wierd pop and somtimes the rear of the car feels as if it moves when the pop occurs. It has happened 4-5 times. I have c5 wheels with 295 35 18's out back. There is no contact issues with the tires or the rims. I have opened up the rear end cleaned and refilled it with syn 75w-90 and L/S additive.
I checked gear wear it looked fine. I tightend the bearing caps etc.. zexel/torsen worm gears look good. I checked down the drive line from rearend to T-56 making sure everything was tight. LCA's, Torque arm, trans mount, trans, u-joints, shocks, swaybar. what else should I check.
Maybe this is normal. I have owned the car a year and never had the issue before. The most recent add on were the C5 wheels and 295 35 18's. Any ideas are welcome. Ron
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
Achilles97
Sep 12, 2002 11:57 AM
JSK333
Sep 9, 2002 10:33 PM
Red97LT1
Sep 7, 2002 09:29 PM
formula79
26
Aug 5, 2002 12:21 PM
