pinion shims and bearing
Old Apr 8, 2004 | 03:22 PM
camaros_4_lfe's Avatar
ok if you have done gears please help
if my pinion depth is wrong with my stock shim on new gears....i have to pull that pressed on bearing off to change the shim dont i? how is that possible without damage? is it? are there alteratives?
ty
Old Apr 8, 2004 | 08:13 PM
nateh's Avatar
You do have to pull the bearing. It shouldn't damage it if done carefully. This is one of the reasons why doing gears can be a pain. The shops that do it all the time use a slightly oversize bearing so they can make the changes quickly.
Old Apr 9, 2004 | 01:08 PM
yeah im either think of just buying 2 new bearings and sand one so it slides on easier and make my adjustments from there
instead of paying 200 for a gear install
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
