Pinion Angle?
Old Aug 18, 2004 | 10:57 AM
a327vette's Avatar
Pinion Angle?
I am putting a moser 9" under my 94 Z. while doing this I am also installing a Random Tech. Adjustable Tq. Arm and G2 adjustable lower control arms with LCA Reloc. Brackets.
Just curious what I should set my pinion angle to and how to find out what it actually is. My tq. arm did not come with a gauge, so do I need to buy one, or is there another way.
The car will be a street car with occasional drag use if that matters.
Stevie
Old Aug 21, 2004 | 06:40 AM
SABLT194's Avatar
Re: Pinion Angle?
If you're not going to drag race hard (ie no slicks) I would put the Pinion Angle neutral - 0 degrees. Negative PA is really only there to account for suspension wrap up and flex when launching very hard. Generally speaking - Flimsy suspension components - crank in some negative PA Stiff components (Torque Arm, LCAS's, etc) less pinion angle. Contrary to some beliefs, Pinion Angle does not help traction. I know I'll get flamed for that one! Fire away
Bobczar
Oct 23, 2015 11:22 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
Aug 7, 2015 01:26 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
kev93z28
Aug 19, 2002 12:48 AM
