Opened the differential cover. What gears are these?
Old Apr 28, 2008 | 04:15 AM
MeanGreen97Z's Avatar
The ring gear had a stamp that said Auburn Gears. Also on the ring gear is said 376 B.L006 and on the pinion 3J6 2.309. I just wanna know what these things are. I've googled and searched the site like mad and found nothing. Auburn's website doesn't even show them making gear sets. Am I losing my mind?
Old Apr 28, 2008 | 07:15 AM
cause4panic's Avatar
what that indicates is that your backlash should be 6 thousanths and that your checking distance from the axle centerline to the face of your pinion is 2.309
Old Apr 28, 2008 | 12:10 PM
blue 79 Z/28's Avatar
if you want to know the ratio, count the ring gear teeth and divide it by he amount of teeth on the pinion.
Old Apr 28, 2008 | 02:04 PM
The_Bishop's Avatar
There should be a pair of numbers stamped into the ring gear that show the tooth counts.
Old Apr 28, 2008 | 07:27 PM
Every other gear manufacturer does this... I spun the whole damn ring gear and found nothing. haha
Old Apr 28, 2008 | 07:35 PM
You should have been counting the teeth as you spun it around.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
TitoPR221
Jan 29, 2015 08:00 PM
Jul 4, 2005 05:00 PM
