Nothing after rebuild.4L60E
Old Jul 23, 2006 | 08:22 PM
97CreamSickL's Avatar
New rebuild from a performance tranny shop in the area.It does nothing.No gears or reverse.Ive put many trannys in the past and I remember getting the torque converter to "click in" properly.Is the eletrical plug critical to get it to engage.The shop put a coat of flat black on it and maybe coated the connections.Im stumpd and beyond fustrated!
Old Jul 23, 2006 | 08:46 PM
lefty's Avatar
Re: Nothing after rebuild.4L60E
It is an electric controlled transmission,clean the connections and try it again.
If not take it back to them.
Old Jul 23, 2006 | 09:45 PM
I did a search as far as how many qts of fluid and somone posted that he put in 12 qts.Is that right?I put in 5 qts and it didnt even budge.I did have a empty converter.On the same thread someone said 7 qts with a empty converter.It should at least engage and move a bit with 5 qts right ?
Old Jul 23, 2006 | 09:52 PM
12SCNDZ's Avatar
Um...A dry 4L60E and a new converter will take around 12-14 quarts. 5 is nowhere near enough.
Frank
CPT
Old Jul 23, 2006 | 10:38 PM
If its as easy as that ll have a good night sleep.Thanx
Old Jul 23, 2006 | 10:46 PM
Cmr0z28's Avatar
WHY was the converter installed dry?
Old Jul 24, 2006 | 01:29 PM
94Camaro_Z_28's Avatar
Simply put, no.
