Not F-body sorry. 727 no reverse after loud pop sound?
Frank, Dana, Rich, or any of you other tranny guru's:
I cranked my 86 Dodge 4x4 truck {727 tranny / np208 transfer}, this morning and attempted to back out of my carport. A couple of seconds after it started pulling in reverse there was a metallic type pop sound like maybe I broke a hard part. After I winched it out of the carport I drove it and it shifted and pulled normally through all 3 foward gears.
I can shift to reverse with light throttle and notice a slight pull on the motor but not near enough to move the truck. There is no abnormal noise.
I replaced clutches, steels, seals, bearings, bushings and pump about a year ago and installed a new higher stall converter. It has preformed flawlessly with cherry red fluid until now.
Any suggestions on what part {s} I'll be needing so I can pull it and fix it all at once.
Thanks for any help.
Re: Not F-body sorry. 727 no reverse after loud pop sound?
I'll drop the pan tommorrow. I suspect it will be the band according to the pop sound it made and according to my fine luck lately. Thanks Frank. I'll post what I find.
I have the pan off now. There are 2 pieces of a broken flat part which looks to be the reverse band actuator strut. I don't have a diagram of a 727 but this 518 diagram is similar enough to show what I'm refering to although my piece {1 1/4" long x 1" wide x 1/16" thick} does not have those notches. It broke dead in the center. I have it circled in red in that diagram.
I backed off the adjusting stud all the way and have a good bit of play but I don't know if I can I get another strut up above that pivot piece without having to pull the pin out of the lever?
The housing between the transmission and transfer case has a small corner covering the hole that the lever pin pin will need to come out of. I'm trying not to have to pull the transfer case. I can break that corner {about 1/4"} off the extension housing if needed in order to pull the pin and weld {heli-arc} it back on after I'm through, but If the new strut will fit in with the lever and pivot piece in place, it should be no problem.
Will I be able to get a new strut in there without dissassembling the lever or do you have a better way?
BTW: The actuator piston was pushed out so far, it had the tab on the lever in a bind at about a 45 degree angle. I pryed it out of the bind and it retracted right back to the bottom of the bore, and seems unhurt. Am I lucky or what.
That's a ton for your help Frank, once again.
It'll go in as long as the band adjustment is lossened. You may have to get it close, and tap it in with a large screwdriver.
You might want to pull the srvo out and check the rubber seal on it.
Frank
Frank
Frank
Frank
Frank
Frank
Anyway, at least I can back up now.
Thanks again for the help Frank
well isn't this special.
I hooked to a friends truck that was stuck in a ditch with a loaded trailer and attempted to pull him out. My tranny acted like it jumped in neutral. It would not pull in either position of the shifter {1-2-D}.
I climbed under it and tightened the front band all the way in and it pulled out in 2nd gear {no truck / trailer attached, we pulled those out later with my tractor}. Now it starts off from 0 MPH in 2nd gear and if I attempt to shift to D {3rd gear} it binds. If I relax the tension on the band it will not pull period. There is also an consistant whining sound while moving. I have little knowledge about diagnosing a 727.
I guess I already owe you a Thanksgiving turkey and now, what would you like for Christmas.
And thanks Frank for the 9 hundreth time.
