noise from rearend when turning left
Old Dec 29, 2004 | 02:56 PM
Guggi97_RA's Avatar
I am hearing an odd noise from the rear of the car when i make a left turn. It feels like something is rubbinh almost, but I know that is not the case. It makes me think that the noise is from the rear end. Any ideas?
Adam G
Old Dec 29, 2004 | 03:46 PM
AL SS590 M6's Avatar
Moderator
Re: noise from rearend when turning left
Adam G
Most times all you need to do is change out the differential lube with new and add some posi additive.
Old Dec 30, 2004 | 08:50 PM
gearslammer's Avatar
Exactly, had the same problem and it fixed it pronto.
Old Dec 30, 2004 | 09:32 PM
1BAD86Z's Avatar
Adam G
Adam,your car has bad differential bearings and if you dont get it fixed a.s.a.p. your going to have to rebuild the whole axle, gear ,bearings and possibly an axleshaft that is not riding ture. from experience i've seen the same thing about 3 times so far. Scott k.
Old Dec 30, 2004 | 10:23 PM
GreenDemon's Avatar
Lube change w/ additive worked for me. If it's a low whining/squealing noise that's probably it. Scraping noises usually indicate something more serious.
Old Feb 6, 2005 | 05:04 PM
Bawls's Avatar
I have the same problem, just did a fluid change, with no resolution.
Old Feb 7, 2005 | 09:39 AM
Guggi97_RA's Avatar
Thanks. I have parked the car, Just bought a truck. Whenever I get it back out. I will have the rear end rebuilt with some 3:73's, and all the bearings... Should take care of the issue.
Adam
Old Feb 11, 2005 | 08:22 PM
ftransam1's Avatar
if it's a high pitched metallic sound than it's probably your caliper rubbing against your brake rotors. I had that problem on my old rear end because of some play on that side. Axle would move in and out a bit. Just a thought
blac94Z
29
Mar 25, 2015 04:21 PM
ddr698
Jan 9, 2015 10:05 AM
CaRParts102
Dec 6, 2014 08:45 AM
squarehead
Nov 21, 2014 08:02 PM
formula79
26
Aug 5, 2002 12:21 PM
