No pressure in Clutch Pedal after replacing Slave
I snapped my clutch fork and had to pull the trans to replace it...i got the trans back in and decided to replace the slave, as the factory one was all bent and ****.
I replaced the slave using the following steps:
-unhook the straps on the new one.
-pour fluid into the slave at a 45* angle till it's full
-pull old slave off
-replaced seal that goes around hydraulic line
-pushed new slave on, and pushed the tension pin back into place
-pushed the shaft of the slave back into the slave itself and hooked up the straps again
then i bolted it up and now i have absolutely no pressure in the clutch pedal
PLEASE HELP!!!
btw its a 95 t/a w/ an lt1
-pull old slave off
PLEASE HELP!!!
