New clutch isn't the same
Old Jun 7, 2009 | 10:12 PM
PewterZ's Avatar
My old clutch was bleeding fluid. I decided to upgrade to a Centerforce and renew/replace all the hydraulics since I was in there anyway. The master and slave cyl look black and worn - original owner must have poured strange stuff into the reservoirs.
The Centerforce grips nicely, but the pedal is way on the floor. The shop does race cars and restorations, and the owner has a 2000 Z so I assume he knows how to bleed the system. Is the pedal position just a result of new and slightly different geometry with the new components, or do you figure there's still air in there.
Steve, Colorado
99 Z28
SLP in, Magnaflow out
Ported throttle body
Old Jun 8, 2009 | 07:18 PM
johnny6's Avatar
"mooshy" pedal = air in the system
Old Jun 10, 2009 | 08:12 AM
AL SS590 M6's Avatar
Moderator
Wrong forum.
Old Jun 10, 2009 | 12:08 PM
97FormulaWS-6's Avatar
Did you replace the slave with an adjustable one? it could be not adjusted properly if so.
If it's mushy, then it's air in the lines.
sleeperZ96BT
Sep 10, 2015 08:01 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
