Need some flywheel help
Old May 29, 2005 | 09:51 PM
madwolf's Avatar
OK, this is basically cliffnotes from my other post.
I installed a T56 in my A4 car and I had some noise with the car running.
Turned out that teeth on a part of the flywheel were touching the ring on the starter shaft.
You can see my flywheel moving here. (7.4 megs)
The flywheel itself is a used aluminum SLP flywheel I picked up from a local guy. It had some weird spots on it, but they were only on a portion of it.
Pictures here: (about 1 meg each)
Pic 1
Pic 2
Pic 3
My question is, is it normal for a flywheel to have the up/down movement (not perfectly round) and should I try to shim the starter or should I get the steel flywheel (that came with the tranny) resurfaced and use that instead?
Thanks.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
