Need to know original thickness of clutch plate
Old Oct 20, 2007 | 07:52 AM
night-rider-69's Avatar
Hello!
Does anybody knows the original thickness of the clutch plate from a valeo clutch (I think it is the original set-up of the Camaro with BW 6 spd.).
Thanks for help.
Old Oct 20, 2007 | 08:24 AM
wrd1972's Avatar
Originally Posted by night-rider-69
Hello!
Thanks for help.
I assume youre more specifically referring to the friction plate measurement. If you look at your plate you will see there is no good reference edges to get a good measurement.
I just took my old used pressure plate and set it upside down on the floor and placed a straight edge across the friction surface. I then measured the distance from the straight edge to the floor. This measurement was 1.470".
Hope this helps.
Old Nov 9, 2007 | 09:26 AM
1 DWN CAM's Avatar
Original thickness is .305" to .320". Minimum thickness is around .240"
*Emilia*
May 13, 2015 09:05 AM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
Ryabut98
Sep 3, 2002 11:45 PM
