Need instructions on how to bleed clutch
Re: Need instructions on how to bleed clutch
Same way you would on brakes. Have someone press the clutch pedal down & hold it then use your wrench to unscrew the nut then tighten and let you friend/ helper release the clutch. Repeat as necessary. Make sure you have fluid in the clutch reservoir.
Formula Steve
Sep 19, 2023 08:31 AM
CARiD
Sep 7, 2015 08:21 AM
