Need help setting up UMI torque arm please!!
So right in the middle of installing, I got a heavy case of the stomach flu. I Just slapped it together to get home to rest. In the 3 mile drive there was alot of vibration. The picture shows my setup http://s970.photobucket.com/albums/a...p.jpg&newest=1
Here are my questions- focused on the Yellow half circles.
1. Since my trans anlge is extreme at +4, can I shim the trans up with some washers between it and the poly mount?? I'd like it at 0 deg if I could.
2. I installed the TA on the "instant center" holes on the bracket for the tunnel mount. Does the angle of the bracket need to be 90 degrees? If it does, do I have to adjust the top eyelet bolt (instructions say don't touch it) to get the angle right?
Am I going in the right direction?
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
Thanks. After recovering from that nasty stomach bug, I put more thought into it. Basically, I need the Poly Mounts on the TA & mount to be 90* to the driveshaft. Also, I tried shimming the trans off of the mount- I got to +3, but my exhaust was on the body and rubbing.
Where I've gone wrong is reading about 0 and +1 as standard engine/transmission angles. So while I have +4, I don't think there's anything wrong with that. Actually, it may be a little better for weight transfer at the drag strip. I'll just set the pinion to +2 and that should result in -2 pinion angle.
UPDATE:
Readjusted the pinion angle and reset the TA bushing angle on the crossmember. No more vibration.
Negatives: There is a little more road noise and the faint gear whine from the s60 from 40-55 is amplified quite a bit now. Also, you can feel the gear lash (clunk) on quick accel or decel, since its no longer absorbed in a stock rubber bushing.
Positives: UMI makes a quality product. On the stock TA, under hard acceleration, I was getting massive shuddering from the rear of the car- that's now gone. Car hooks up immediatly now. The weight transfer feels much better. No more worries about breaking anything from the tailshaft on back when I hit the dragstrip. Time to buy sticky tires now
UPDATE:
