Need help!! 4L60E starting in 2nd gear
well i just put a new tranny in and thought i had a major power loss because it does not throw you back in the seat like my stock tranny did... and the hint that i used 1/4 tank of gas going to work this morning didn't help things much either.... so i take it to the shop that built my trans and had them scan the computer. it is showing 1 and 2 silonoid on when only one or the other should be off.
The Trans tech that built my custom trans said i had a wire pinched somewhere that was grounding it out causing the silonoid not to function right. Any idea what wire? is this BS?? let me know because its going in the shop in the morning and its going to cost me $54.00/hr to fix it!!!!
I'm open for ideas and suggestions
Thanks Guys/Gals
Thanks Guys/Gals
Jul 4, 2005 05:00 PM
