Need grade8 bolts for rearend cover?
Old Jun 22, 2005 | 01:48 PM
pHEnomIC's Avatar
My rearend is leaking at the gasket. I just changed the fluid about 1000 miles ago and i cleaned the old gasket off real good, applied orange rtv and stuff. I am gonna have to redo it i guess because of the leak. Most of the bolts down there are almost rounded out so i would like to put in new ones. I am using stock rear end cover.
Do i need to go through the extra trouble and costs to get grade 8 bolts for it?
or can i just use the matching bolts from aco or whatnot
(I know they aren't grade 8 but i dont think that they are the weakest ones either, i forgot)?
BTW,
Also, theres a bolt missin on my alternator i need to replace. Do i need a grade 8 bolt there or will anything work?
Old Jun 22, 2005 | 02:03 PM
rskrause's Avatar
Moderator
Re: Need grade8 bolts for rearend cover?
I think regular hardware grade stuff is fine for the cover.
Rich
Old Jun 22, 2005 | 10:29 PM
respectirocz's Avatar
grade 5 is probably more than enough for the diff cover, the cover doesnt do anything besides hold the oil in so its not under high stress
many auto parts places have gm alt bolts
Old Jun 23, 2005 | 09:40 AM
OBE1 95Z28's Avatar
None of the bolts that you described see high loads, therefore Grade 8 hardware is overkill.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
