Need to beef up my rear end without getting new one
Old Mar 27, 2004 | 02:03 PM
formula king's Avatar
what should i get so i dont break anything when i launch
(axles etc.) I already got my spec stage 3 clutch put in, and next week im having some nitto's and 4.10s put in (other mods in sig)
i just want to be safe and not break anything when i launch(worst case sen.)
also are 315 nittos a must on some 4.10s or are the 275 good enough
Old Mar 29, 2004 | 06:54 PM
BC94Formula's Avatar
http://www.thirdgen.org/newdesign/te...nguprear.shtml
this is the only article i have ever seen about beefing up a 10 bolt...not sure if the third gen 10 bolts are exactly the same...but i think some of the stuff might translate over if they arent the same
Old Mar 29, 2004 | 07:59 PM
ABA383's Avatar
I think CHP just did an article on the 7.5 10 bolt....Moser says that with their 28 splined c clip axles, their gears, and a TA style cover it will handle 400rwhp...
--Alan
Old Apr 1, 2004 | 10:16 PM
camaroz28_97's Avatar
from what i have seen it is NOT posable to beef up the 10 bolt. you can make it a little stronger but in the end it will blow. If i were you i would just do what i did do and save for a 12 bolt
Old Apr 3, 2004 | 12:01 AM
ishz28's Avatar
Not to start any wars, but I have the TA diff. cover and have broken three sets of gears with an A4 on street tires. I highly doubt the 7.5 can take anywhere near 400Hp! Also, wasn't there a rear end on the thrid Gens, that came in 8.5"?
Old Apr 3, 2004 | 06:03 AM
Red5.7's Avatar
I don't know, I have heard of guys running into the mid-11s on the 10 bolt, running drag radials. That would be a fair amount of power if you ask me.
Anyway, it all depends how they got to the "handeling 400 rwhp." Do they mean handle as in 1 good pass down the track, or just being able to make a 400 rwhp pull on the dyno. Or do they mean into a strip car that makes many passes a year. It all depends in the context that they arrived at their claim. But I hear Moser makes good stuff
Anyway, I blew the stock posi to pieces last year. I didn't have the money to invest in something bulletproof and I wanted to get going.
I did the TA girdle, solid pinion spacer, Eaton posi, and US/Strange Gear 4.10. I am going to the track on Wednesday, and plan for it to hold. Granted I am a bolt-on car, but the M6 can unleash a fury. I may have my buddy weld the axle tubes up though.
Old Apr 3, 2004 | 07:58 AM
ABA383's Avatar
I believe that the 7.5 is weak...however....I've been running stock axles, a Pro Auburn, GM 3.42 gears, Red Line fluid, stock cover and 420rwhp thru BFG DRs since 1995....1.60's - 1.70's 60's..the only casualty was an Aurburn wearing out...Since I've had the Pro Auburn (1998) no probs.....guess I'm just lucky I do realize that M6 cars are way harder on rears than A4's....
--Alan
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
