Is my car a 3 speed????
Old Sep 6, 2005 | 05:08 PM
CHELOZ28's Avatar
Well the reason i'm asking is my console only shows the following P,N,OD,D,2??
I was thinking about getting some 3.73 gears, would I be still okay on the freway??
Old Sep 6, 2005 | 05:09 PM
Jazsun's Avatar
Re: Is my car a 3 speed????
ull b fine
Old Sep 6, 2005 | 05:13 PM
KyleBlue85Iroc-Z's Avatar
I'm fairly certain that means you have the 2.73 gear option. The 3.23's came with the 1st gear option.
And yes, you have a 4 spd automatic 4L60E.
MyShibbyZ28's Avatar
It's a three speed auto with overdrive. If you go to 3.73's you'll be turning about 2500 RPM in OD. You're gas mileage might drop about 2 mpg give or take some. 3.42's turn 2350 at 70.
Old Sep 6, 2005 | 05:18 PM
Jazsun's Avatar
mine car gas 3.23 and has 1-2-3-D
Old Sep 6, 2005 | 05:22 PM
CHELOZ28's Avatar
so basickly I will be fine with 3.73's.
thanks guys
Old Sep 6, 2005 | 06:00 PM
cammed_aro Z28's Avatar
not having the first gear option means that your car is equipped with 2.73 gears. i got in an argument with my neighbor when he got his camaro and he said his was different than mine because it was a 93 and mine was a 94, went and talked to the dealer and that is when i found out that the 2.73 cars didnt have 1st gear option. i have heard no trouble from people running 3.73's. just remember, if you do indeed have the 2.73 car, you have a different rear end carrier and you have to order the right ring and pinion for your carrier.
Old Sep 6, 2005 | 06:08 PM
CHELOZ28's Avatar
i was going to purchase richmond gears, also will it be a good idea to purchase a new differential? What is the difference between limited slip, posi and what would be the best?
Old Sep 7, 2005 | 12:02 PM
87DJP2001's Avatar
You have a 4L60E 4-sp automatic tranny. Cars with a 2:73 gear ration did not have 1st gear maked on the shifter. You still have a 1st gear but it cannot be held in that gear the Tranny's electronics handles the shift from 1st to 2nd.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
