Is my car a 3 speed????
Well the reason i'm asking is my console only shows the following P,N,OD,D,2??
I was thinking about getting some 3.73 gears, would I be still okay on the freway??
Re: Is my car a 3 speed????
not having the first gear option means that your car is equipped with 2.73 gears. i got in an argument with my neighbor when he got his camaro and he said his was different than mine because it was a 93 and mine was a 94, went and talked to the dealer and that is when i found out that the 2.73 cars didnt have 1st gear option. i have heard no trouble from people running 3.73's. just remember, if you do indeed have the 2.73 car, you have a different rear end carrier and you have to order the right ring and pinion for your carrier.
i was going to purchase richmond gears, also will it be a good idea to purchase a new differential? What is the difference between limited slip, posi and what would be the best?
Jul 4, 2005 05:00 PM
