More T56 Problems
Old Sep 30, 2006 | 04:49 PM
Stevo's Avatar
More T56 Problems
I just got done with my T56 swap and it now has a Mcleod Twin Disk Clutch setup. Well after it being a pain in the *** it finnally all works. I have no reverse and the throwout bearing is....loud.
Any help and has anyone else had problems like this? I can put it in reverse and the lights light up but it just doesnt move it i mess with it it starts making a slight wine/grinding noise? Is the gear gone or is it just not going in correctly.
I need help ASAP thank you!
Old Sep 30, 2006 | 05:13 PM
ssean92's Avatar
Re: More T56 Problems
sounds to me the throwout bearing isnt seated in the clutch fork properly
Old Sep 30, 2006 | 07:32 PM
Stevo's Avatar
Ya i had inpected the throwout bearing and the fork twice to make sure it was going on it properly. At this point i honestly cant tell, there is not enough room to visably see if its attached right. It only wants to go on the TO bearing one way.
Also another question should the clutch fork move around a lot once its positioned?
Old Sep 30, 2006 | 07:50 PM
ssean92's Avatar
there will be some play, but not alot
Old Sep 30, 2006 | 07:57 PM
Stevo's Avatar
well then i think thats not my problem, its probably normal
Old Sep 30, 2006 | 08:00 PM
ssean92's Avatar
did you get the tranny in flush before you used the bolts to tighten it???? well i guess what i am saying u didnt use the bolts to drawl the tranny to the block did ya?
Old Sep 30, 2006 | 08:02 PM
Stevo's Avatar
ya i did do that actually.
Old Sep 30, 2006 | 11:52 PM
Stevo's Avatar
Maybe i need to ask this:
How do i properly adjust a Mcleod Adjustable Master Cylinder?
Old Oct 1, 2006 | 07:10 PM
Stevo's Avatar
anybody at all?
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Devinfoote87
Parts Wanted
Apr 14, 2015 04:29 PM
InfernalVortex
Jan 17, 2015 09:35 AM
FireAm94
Aug 10, 2002 09:32 PM
Zone
Aug 2, 2002 04:36 PM
