Gears
Gears
I have 4.10's but the pinion nut came loose and screwed them up. Looking at buying some 3.73's or 4.10's Its a daily driver and i see the track maybe 3x a year.
Where should I buy my gears from, Im looking for some US Gear because I hear they dont whine (or not as much)
Also should i stay with 4.10's or go to 3.73's
Re: Gears
dunno about where to buy, but if its just a 10bolt, it would be safer with 3.73, and i hear its better on gas than the 4.10. i heard rearend won't hold up to 4.10 for too long. how did it feel/hold up for you? how long since you put it on?
Re: Gears
I would recommend some Motive 4.11's. They are stronger then the 3.42's, 3.73's and 4.10s that all use a 41 tooth ring gear, 4.11's are 37 tooth ring gears. They also use a lower tooth count pinion gear with 9, vers. 10, 11, 12.. Less teeth = larger teeth = stronger teeth. Grease used to have a side by side picture on his website, a night and day difference. I would recommend a solid pinion spacer as well while your in there. There are a few people on here if you dig around that are running these gears on ET Streets for quite some time without any problems, knock on wood..
Craig
Craig
Re: Gears
Originally Posted by importeater
... Less teeth = larger teeth = stronger teeth. ...
Craig
Craig
or
More teeth = less torque/pressure exerted per tooth (more distributed load), so they don't need to be as strong.
I am not saying one is better over the other, just that real world differences may not be so great.
ChrisFrez
Mar 22, 2015 09:12 AM
