McLeod single: Will it hold?
Old May 23, 2006 | 11:24 PM
  #16
96SilverZ's Avatar
Re: McLeod single: Will it hold?
the only thing I don't like the amount of pedal travel it requires to disengage. I would like it a bit higher for quick shifts.
Pedal feel is like stock. It is a Valeo PP after all...
Old May 24, 2006 | 01:41 PM
  #17
1BadZ95's Avatar
Originally Posted by 96SilverZ
Just got the car back from my mechanic. Disengagement is almost to the floor. I'm hoping that changes during the break in...
Thats exactly how mine is. Infact when we first put it in there was no clutch at all, we made the master adjustable now its just right at the floor and really hard to shift.
Old May 24, 2006 | 07:38 PM
  #18
96SilverZ's Avatar
I drove mine to work today and it's getting better.... Try driving around town for a while. It should come around.
Old May 26, 2006 | 02:43 PM
  #19
96SilverZ's Avatar
Pedal engagement is right around stock now. Hasn't started chattering yet, about 350 -400 miles to go...
Old May 26, 2006 | 03:29 PM
  #20
njenson's Avatar
My mcloed started off that way too.. after it broke in a bit it just moved towards the top. the thing is now im a little worried about the engage point about an inch from the top of the pedal... so i guess im not sure what is going on
Old May 26, 2006 | 04:22 PM
  #21
jsetzer's Avatar
I had engagement problems with mine at first.
I have 2k on the clutch now and it feels fairly normal, if it doesn't come up a bit higher though I may do the homemade master cyl.
I have the 7500 disk and a spec PP.
Old Jun 2, 2006 | 02:27 PM
  #22
96SilverZ's Avatar
OK, It's been chattering for a couple days, and I've put around 475 miles on it(instructions say 450-500). I was on my way to go get the bottle filled and figured I better see how it shifts NA before I spray it. It won't even chirp second with the M/T radials. My old SLP clutch would chirp them easy before it wore ou. WTF????
Old Jun 4, 2006 | 07:52 PM
  #23
96SilverZ's Avatar
I just talked to the mechanic that put my clutch in. When he had the flywheel resurfaced he was told it was still well within specs, so that's not it.
Don't know if this has anything to do with it, but when it was first fired up after the install, the fork was contacting the PP. We called Summit(where I got the clutch) and they said just to drive it for a few miles and it will be ok. We did that and it seemed to be fine...
Still slips going into second at WOT....
G-BODYT56
Jan 14, 2022 11:14 PM
LT14LIFE
Nov 15, 2015 06:22 PM
PopoFormula
Oct 12, 2015 04:19 PM
CARiD
Sep 30, 2015 05:44 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
