Mcleod clutch install
Old Dec 15, 2009 | 10:19 PM
Black 97 SS's Avatar
A couple quick questions. I have a McLeod 7500 rpm single disc I'm reinstalling in my camaro because I just put the new McLeod bell housing on. Do the Kevlar pucks mate to the pressure plate? This seems to be the only logical way to reinstall the clutch and pressure plate do to fitment. There used to be a sticker that said this side towards flywheel but it is no longer there. I just wanted to double check things before I reinstall the trans. Also I found a couple different torque specs for the pleasure plate, I used 22 ft lbs, does this sound correct. Thanks in advance for the input .
Old Dec 16, 2009 | 04:51 PM
Spartan7's Avatar
The part of the hub that sticks out past the friction surface goes towards the engine. 22 ft lb sounds about right for the PP bolts.
thanks a bunch thats the way i put it on, Jason
Nov 18, 2023 07:21 PM
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
