McLeod big trouble, please help ...
Hi there, I have got problem with McLeod Dual Clutch kit.
Last thursday I put my McLeod Clutch kit with flywheel in my car and adjusted master clutch cylinder as it is told - 1" under brake pedal. The clutch was handling great, except 1st gear and rear which were hard to shift, but not so bad. I went to drag races today. On the road, there was traffic jam, so we were moving about 20minutes at the speed of walking. After that the clutch smelled bad and it was hard to shift. I let the car cold down, It was OK then. I run about 8 times and suddenly the car stopped down. Clutch pedal is easy to push. I decided to open brake fluid reservoir and the fluid splashed all over. Again, I let the car cold down, but nothing happened, the clutch is dead. What is wrong? I bought McLeod, because my car have already eaten Valeo clutch. Where is the problem?
Thanx
Marauder
Thanx
Marauder
Re: McLeod big trouble, please help ...
Thanx
Marauder
Thanx
Marauder
Ya, it sounds like you didn't let it break in for starters. Supposed to put 500 EASY miles on it before getting on it --- let alone taking it to the dragstrip.
Is this washers set up good? If not, could it brake the friction plates?
http://www.autohifi.cz/dforum/pictur...37-30_1232.jpg
Thanx
Marauder
Thanx
Marauder
Thanx
Marauder
Thanx
Marauder
NewsBot
Aug 3, 2015 02:40 PM
pull the tranny and get a better look..
