Master cylinder question...somebody help!
Old Jul 14, 2007 | 10:07 AM
rardiz's Avatar
Alright so I replaced my clutch about 5,000 kms ago...I reaplced everythin clutch plate,flywheel,slave cylinder, did the drill mod....Oh and its from carolina clutches...But the only thing I didnt replace was the master cylinder...Now its a 98 Ls1 and the problem I am havin is that I believe its drawin air in from somewhere...Its gets hard to put into gear and if I bleed the clutch its fine for a few weeks and it needs bled again..My question is this does it sound like my master cylinder is pooched and if so do I need an adjustable one or is a new one from GM say for like 2000 camaro gonna be fine? Or are you better off with one for a z06 or somethin?
Thanks in adavance Gerard
Old Jul 15, 2007 | 07:54 PM
rardiz's Avatar
bump
Old Jul 17, 2007 | 08:10 PM
BlackDog's Avatar
Try this - http://performanceworks1.com/ls1_clutch_bleeding.htm
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
