M6 swap, reverse now blows gauge fuse
Old Sep 22, 2008 | 05:03 PM
PoorMan's Avatar
Hey guys.
I swapped my A4 for an M6 along with changing to a same year M6 engine harness. Ever since, whenever I shifted into reverse, I would immediately blow the gauge fuse.
I have now unplugged the factory reverse plug at the trans and connected a new plug that I wired directly to the reverse portion on the A4 plug under the center console. It works fine now. I was just wondering what I maybe bypassing that would now cause this to work and is it safe to do? could it overheat, melt, etc?
Thanks for your time.
JD
Old Sep 22, 2008 | 07:26 PM
Green96Z's Avatar
If you look at the schematic, the wiring for the reverse lights stays inside the car after the fuse block on an auto. But on a manual, notics P110. That is the big connector where the engine harness and I/P harness meet. The manual wires go outside the cabin to the reverse light switch on the tranny, then back inside the cabin and to the reverse lights.
I don't have the 94 wiring handy, but maybe when you replaced the engine harness the wires for the reverse light switch were meeting up with something they shouldn't be on the I/P harness, and it was shorting out your guage fuse. The way you have it wired now is the correct way to wire the reverse lights.
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
mackirockz
Feb 4, 2015 07:03 AM
jayvar
Feb 2, 2015 10:00 PM
$hawn
Aug 17, 2002 04:37 PM
