M6 doesnt feel right
Old Oct 11, 2003 | 03:37 AM
unTAmedLS1's Avatar
Its kind of hard to explain but Ill try....well I put new stage 3 spec in and everything was great for about 250 miles then it started feeling like soomething was loose...For instance when I would do a 2-3 upshiftit wouldnt feel as solid as it usually did it was more like I had to search for the gears.... I have a hurst shifter btw so usually 2-3 is smooth but feels like there is too much play when shifting so I thought it mught be the trans mount bolt coming loose or something but that was fine. Could it be the shifter bolts being loose? I know this is not a good explanation but I cant descrbe it all that well. Basically its just not as tight as before it feels a little more notchier and doesnt feel like its all the way in gear when it really is...also when I give it gas the shifter rises up like it ddoes when u need a new mount but I have a fairly new poly one so I know thats not the case.
Old Oct 11, 2003 | 08:37 PM
Rodrigues's Avatar
I would guess its the shifter bolts coming loose, that has happened to a friend of mine or the springs inside the shifter going bad.
Old Oct 11, 2003 | 08:50 PM
unTAmedLS1's Avatar
yeah it was the acyual bolts on the stick there was a ton of play
Hal Fisher
Sep 30, 2015 09:03 PM
Bxlt1
Sep 29, 2015 03:18 PM
colts0455
Sep 27, 2015 01:07 PM
greenzee28
Sep 25, 2015 04:29 PM
