LT1 Driveshaft history questions
Subscribe
Dec 11, 2004 | 10:16 PM
Did any LT1 cars come with an aluminum shaft or were they all the dreaded vibrating steel dissasters. I am well aware of the upgrade options but I wanted to know a little history on what LT1 cars (if any?) recieved an aluminum shaft. I have a fully optioned '95 M6 with a steel shaft and was under the assumption that no balanced aluminum shaft was avaialble until the LS1 switch in '98. Dissregaurding the 1LE option (which I know was aluminum for 3rd and 4th gens alike) am I right? All my book/internet research and board searches come up with every LT1 car getting a steel shaft but recently I have been notifed that some did indeed come with an aluminum shaft.
Reply
Dec 11, 2004 | 10:50 PM
Re: LT1 Driveshaft history questions
Quote: Dissregaurding the 1LE option (which I know was aluminum for 3rd and 4th gens alike) am I right? All my book/internet research and board searches come up with every LT1 car getting a steel shaft but recently I have been notifed that some did indeed come with an aluminum shaft.
To my understanding, all 4th gen LT1 cars came with steel driveshafts. 1LE cars included.
Dave
Reply
Dec 12, 2004 | 08:19 AM
I believe they were all steel units for LT1 cars, I don't know about the 1LE though.
I will let you know that the LSX DS did nothing to fix the vibration problem I was having. I ended up getting a Denny's (Which is balanced to over 8000rpms) and now my car is like glass up to 145, whereas with the vibration I maxed out ~80 before I didn't feel safe in the car and the fillings began falling out of my teeth.
Reply
Dec 12, 2004 | 10:13 AM
I was under the same assumption. I needed some varificiation for a disscussion that i recently had with someone who said aluminum shafts were common. My previsous thinking may be inccorect but everything i dig up tells me otherwise. I have yet to find a non 1LE aluminum DS LT1 car.
Reply
Dec 12, 2004 | 02:31 PM
Reg. LT1s received a 2.5"? steel driveshaft
1LE LT1s received a 2.75" alum. driveshaft
LS1s received a 3" alum. driveshaft
V6s received a 1 or 2 piece steel driveshaft, depending on year?
Are you trying to figure out if yours came stock like that? I don't think any non-1LE LT1s came with them. You can always get down there and see which one you've got- get a string and a ruler, measure the circumference, divide by pi...
I'm not sure it's that big of a deal though, some aftermarket place sells 3.5" ones for a little over 300 I think.
Reply
Dec 12, 2004 | 02:42 PM
Quote: I was under the same assumption. I needed some varificiation for a disscussion that i recently had with someone who said aluminum shafts were common. My previsous thinking may be inccorect but everything i dig up tells me otherwise. I have yet to find a non 1LE aluminum DS LT1 car.
I have one, 1995 Z28 LT1 Group II MN6.
I had the factory steel shaft and 3.42 gears. There was a TSB about vibration with the steel shaft. I think the lower gear ratio made things worse, A4 had 3.23 gears I think.
If you knew about it and took the car in, the dealer would install an aluminum drive shaft.
I think the shaft is the same as the 3rd gen 1LE shaft.
As far as I know that was the only way aluminum shafts were installed on LT1 from the factory.
I think the LS1 cars all had aluminum, but I really haven't done much research.
Reply
Dec 13, 2004 | 05:04 PM
I know I have a steel shaft but was wondering if you could get an aluminum shaft via option or standard OEM. I have yet to find any LT1 with an aluminum shaft that is not a 1LE but I have had some people say that is was quit common. I don't want to beleive him yet because everyone says the stockers were steel.
Reply
Dec 13, 2004 | 05:36 PM
I don't think 4th gen 1LE's got the aluminum driveshaft. Mine is a 94 1LE and it has the steel driveshaft.
Reply
Dec 13, 2004 | 05:49 PM
The people who complained under warranty got the alum replacement, I have a steel one in my car, isnt bad at all.
Reply
Dec 13, 2004 | 07:09 PM
Quote: The people who complained under warranty got the alum replacement, I have a steel one in my car, isnt bad at all.
This seems to be the conesensus.
Reply
Subscribe
