LT1 clutch bleeding ...
>Does anyone have the LT1 clutch bleeding proceedures ? I replaced my clutch master cylinder and the actuator (Mcleod part at clutch pedal and GM part with the resorvoir to the transmission) .
Remove slave from tranny.Push the piston all the way to the bottom holding it piston facing down.Have some one pour brake fluid into the resivoir to the line while you are holding the the pistion in.When it is full install rubber boot and cap then you can let the piston go.Install it back on tranny and go have some fun.
Rob.
Rob.
Redbird
Sep 14, 2002 09:18 AM
