LT1 4l60e bolt up to LS1?
Old Jan 10, 2007 | 09:32 AM
mjf_z28's Avatar
My friend is putting an LS1 into his 97' formula A4, what needs to done to get the 97' tranny to bolt-up to the LS1? Would it be easier or cheaper just to get one that is for a 98+ car?
thanks!
Old Jan 10, 2007 | 10:32 AM
jay_lt4's Avatar
the trans will bolt to the engine just fine, you will loose 1 bell housing bolt on the pass side , no big deal,,
for the converter you will need the hughes crankshaft spacer($40 from summit or jegs) or go with the gm 6.0 crankshaft spacer
oval out the holes in the ls1 flexplate just a bit to match the lt1 10.5" bolt pattern(i have done this and it worked fine)
i personally know all this info to be true from several ls1,5.3,6.0 engine trans swaps that i have done
Old Jan 10, 2007 | 02:38 PM
Javier97Z28's Avatar
Moderator
Good to know, that way I can x'fer over a CPT trans later onto an LS1 if I decide to jump platforms (not cars)
HectorM52
Jul 30, 2017 11:46 AM
ddr698
Jan 9, 2015 10:05 AM
thenewkid
Nov 27, 2014 09:41 AM
