ls1 rear into lt1 car?
will it work
1. will the lt1 rear brakes work on the ls1 rear
2. the ls1 rear is 4 channel i have three, i know that my rear abs will not work and it will set codes but will it still work or any issues i should be aware of thanks alot
Actualy a guy put an ls1 rear in a pre 97 v6 and it worked fine brakes and all, I think he eventually bumped up to ls1 brake swap in the front once he rounded up some money.
He said it was fine on the street and even under hard braking but I am sure his braking was not ideal for racing, but still streetable.
His car was OBDI, and his ABS worked fine.
With the abs in he rear couldn't you just swap over your current ABS reluctor ring or jsut put a new one in it out of an lt1 car?
ChrisFrez
Nov 23, 2014 10:33 AM
Jul 4, 2005 05:00 PM
