ls1 4l6e swap into a 94 lt1?
lt1 trans will go into a ls1 with a tci flywheel(dual bolt patterns) and a sleeve for the converter snout
ls1 into a lt1 wont because of the converter snout being too big...you could have it turned down and possibly it would work with a lt1 dual bolt pattern flywheel
btw swapping the lt1 trans behind a ls1 requires swapping the shift and lockup noids from a ls1 trans...
Jul 4, 2005 05:00 PM
