lot of play in my steering
Old Nov 30, 2012 | 10:47 AM
mahemmjr's Avatar
Have a lot of " play" in my steering. A mechanic said everything's solid and it might be in the trans? Any help?
Old Nov 30, 2012 | 11:37 AM
Zfbod94's Avatar
Re: lot of play in my steering
Check the "rag" joint on the lower steering shaft. Its covered by piece of plastic. I just bought a steering shaft for a LS car, needs to be re indexed, but will eliminate the sloppyness in the steering. Other companys sell a solid plastic disk you can replace the "rag" joint with if you dont want to go the LS shaft way.
Unless you have an internal problem with the steering rack, this should be your problem.(since you said everythings tight up front). What did your guy mean by it might be in the trans? Last time I checked the trans makes your can go forward not used to make turns...hahaha
Old Nov 30, 2012 | 02:41 PM
mahemmjr's Avatar
Indeed. I will ans I was confused by his statement
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
PROJECT X
Apr 17, 2015 12:13 AM
ro2207
Dec 4, 2014 06:18 PM
IrocSS85
Jul 18, 2002 10:35 PM
