A Little Differential Help
Old Mar 15, 2004 | 04:56 PM
MRBoss429x's Avatar
Hey all. Recently my posi took a dump and I'm looking to replace it but am a little unsure what to look for. If read several posts on eaton, auburn, and torsen.
I guess what im looking for is the cheapest (but not an utter peice of crap) set up. Whats the difference between an eaton posi and the torsen differential? About how much would a new posi, or posi-like, unit go for with a set of 3.73s and where could I get them.
Ultimately this is for a daily driver, so I dont need anything radical. It may see a little track time, and occasional burnout, and some sideways-getting (what probably toasted the old one in the first place). I dont have much money, but its embarassing leaving a one-legger and it just doesnt drive the same, much less fun. Anyway, thanks for any information.
P.S. mods, feel free to move this to driveline (where it probably belongs), I couldnt acess that section for some reason
Old Mar 15, 2004 | 05:06 PM
justens95z's Avatar
i would probably just check eBay, there are always some fresh takeoff's for 7.5"s for cheap.
Old Mar 15, 2004 | 07:09 PM
Brent94Z's Avatar
Super Moderator
MRBoss429x, I'll move it. Let me know if you are still have problems getting into that forum. Not sure why you could get into this one and not the Drivetrain forum
Old Mar 15, 2004 | 07:25 PM
ABA383's Avatar
If you want to go with new stuff check out Power Train Truck and Auto Parts 1-866-589-GEAR. They have been the cheapest I've seen so far..They have a package which includes an Eaton Posi, Precision Gears (your choice of ratio), and a master overhaul kit which includes all Timken bearings (except axle), CR pinion seal, OEM ring gear bolts, shims, OEM crush sleeve, OEM pinion nut, cover gasket, and marking compound for $559.97 + $39 to ship it...I talked to Kevin when I called them...Also for a couple bucks more they have GM gears...Also Randy's Ring and Pinion has good prices too...
--Alan
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
'02 Collecter TA WS6
Mar 13, 2003 02:16 PM
jimlab
Advanced Tech
14
Oct 20, 2002 04:02 PM
