Limited Slip Rebuild
Old Apr 22, 2010 | 09:52 AM
The Inferno's Avatar
I have a 1996 Z28 M6 car that I auto-x regular. I am am starting to get bad one tire fires, especially on corner exit. From what I have found out so far I believe it is an auburn style diff with a 3.23 rear gear. I have talked to a few guys that say you can rebuild these with new clutch packs and either shimming the springs or replacing the springs. The only issue is I do not know where to find the new clutches or a rebuild kit. Does anyone have any ideas. I would rather not replace it if I can help it. Just to much money. One of my friends just came across an extra 10-bolt with 3.73's in it. He plans to swap that into his A4 car that has ASR. I know his is a series 2 carrier, am i correct in saying that his carrier will not bolt up to my gears.
Old Apr 23, 2010 | 07:25 AM
AL SS590 M6's Avatar
Moderator
AFAIK the stock Auburn is not rebuildable, there is no rebuild kit for it.
And you are correct, your 3.23s will not fit his carrier.
Old Apr 23, 2010 | 10:06 AM
FirstYrLS1Z's Avatar
^^^agree.
clutchpaks in eatons are rebuildable/replaceable,cone clutches of auburns are not.
Old Apr 23, 2010 | 11:31 AM
I auto-x with a guy in scca that has had his LSD rebuild. In a 96 lt1 car.
Old Apr 23, 2010 | 11:34 AM
dangalla's Avatar
are you sure he did not have as replacement lsd
Old Apr 23, 2010 | 11:41 AM
He said it was still the stock one rebuilt with a Kevlar clutch pack by another SCCA club racer.
Old Apr 24, 2010 | 06:08 AM
That would have to have been an Eaton to get Kevlar clutch pak as Auburns are metal friction cones.
Old Apr 25, 2010 | 10:35 AM
ok well in that case. what would be my cheapest and best option. I really dont have them money to put in to buying a brand new lsd. Is it worth swapping one out of another car. Maybe out of a newer car?
ZXXVIII
Sep 1, 2015 10:13 PM
1slow93z28
Sep 1, 2015 06:22 PM
wesley81
Jul 27, 2015 11:31 AM
Jul 17, 2015 02:47 PM
