Knocking from rear end
Old Mar 20, 2011 | 05:22 PM
95Z28LT1-PA's Avatar
I have a 2000 Z28 with a A4 transmission...I noticed that it knocks in my rear end, but...it only does it when I'm not on the gas or on the brakes. When I'm coasting it knocks pretty loud and it comes from the rear end and if I pull out abuptly it has a loud knock.
Old Mar 23, 2011 | 06:48 PM
EvilElvis's Avatar
Re: Knocking from rear end
Exactly what mine did, it got louder and louder until I replaced it.
Old Mar 23, 2011 | 08:13 PM
What did you replace?? The rear end...driveshaft...gears
Old Mar 24, 2011 | 06:36 AM
redneckgames's Avatar
I had a similar issue once. My cross shaft retaining bolt had came out and was wedged b/t the carrier and the ring gear. The "thuding" mine was making was coming from the pinion gear hitting the bolt on every rotation. Im very lucky the cross shaft didnt come out.
I would jack the car up and check. It is going to be either a u-joint or something in the rearend. It could just be a bearing. If the U-joint feels good, run the car in gear up on a jackstand while safetly taking a stethoscope to the rearend near the bearings. This will help you pinpoint where the noise is coming from. And please use a friend to help.
Old Mar 26, 2011 | 02:19 PM
Well my back driver's tire was loose to the point it snapped two studs, good thing it didn't fly off. I have no clue how I didn't see this...what a idiot I am.
Anyway, still had a pretty loud bang whenever I accelerate really hard..but no knocking while driving
Old Apr 16, 2011 | 10:28 AM
JP95ZM6's Avatar
For the bang, check your torque arm bolts and front mount. The mount is probably most likely. It can be tough to tell visually, so also look for witness marks where the arm is hitting the floorpan.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
