keep me real with yank 3200 ss
i'm getting a yank 3200 super stock torque converter and i keep seeing post where people say "get 3:73's!"
however yank specifically says that this converter is for the corvette with 3:15 gears...
i plan on running this converter with 3:23's (stronger gears) and i'm just wondering if i'm going to be facing obsticals?
please, give me your take...
http://www.converter.cc/converters/street/GM/2/main.htm
superstock is 2.1 STR...... read the faq up top. It will explain what STR is
I can't really explain it well.....rich krause can
check this out too
http://www.converter.cc/tech_talk/tech_main.htm
check this out too
check this out too
check this out too
i read it all... and my conclusion is that i don't want too high of an str because it will hurt my top end or the last 1305' of the 1/4...
i may go for the 3000 with a 1.9 str... i guess it all has to flow together...
i am also going to get a mild cam from Bret so i'm sure that will affect my desision...
why can't this be easier
thanks... str=stall torque ratio...
i'm going to go 3200 and when i get the 9" with 3:83's then i should be good-2-go...
but in the mean time i'm going to run my current 2 k stall with 3:23's...
so maybe 1-2 yrs from now i can upgrade to the 3200 converter and 3:83's a the same time and notice a huge difference...
CARiD
Sep 7, 2015 08:21 AM
