Keep 3.42 or go with 3.73?
Old Sep 29, 2009 | 07:58 PM
  #16
Z-RATED94's Avatar
Mystery Bird, I leave off idle and dead hook every time. What kind of air pressure are you running? What size tire on what size wheel?
Old Sep 30, 2009 | 02:02 PM
  #17
Mystery Bird's Avatar
I've found best results with 18PSI, Tire size 17".
Old Sep 30, 2009 | 03:58 PM
  #18
Z-RATED94's Avatar
The short sidewall of a 17" tire isn't helping your traction any. That's why many guys run a 15" wheel, more sidewall.
Old Sep 30, 2009 | 05:39 PM
  #19
I know, but I got a wicked deal on them. Huge improvement over street tires though.
Old Oct 5, 2009 | 08:31 AM
  #20
redneckgames's Avatar
To further answer your original post.
No dont swap. Gears and converter are not your problem at this stage. Traction is. LCARs may help, adjustable shocks will help, different tires will help. Adding torque with a gear swap or converter change will only make wheel spin worse.
Old Oct 12, 2009 | 01:20 PM
  #21
Prorac1's Avatar
I always launched my auto 94 z from an idle, flashing the converter on take off. With a stock style suspension, imho, its your best bet to get the most snap from the converter. My 60s were always higher whan flashing rather than bringing it up on the converter. My best et was a 12.81 @ 106 with a 1.77 60 ft. Not the greatest 60, but pretty good considering the time and mph. Another great investment is an adjustable torque arm. Play around with your pinion angle to see what gets the best results, but i usually had the best results with -3 or -4 degrees of pinion angle. Stock shocks, stock boxed control arms, 3.73 gears, and 3600 converter, on a 26 x 11.5 et street. Hope this helps, Eric L
Old Oct 13, 2009 | 06:49 AM
  #22
I've contacted Andre at Edge and he gave told me no problem to re-stall my converter from 3000 to 3600. I also found someone that will set up a set of 3.73 gears for some exchange work. So, after I get larger injectors I'm going to do both, the higher stall and 3.73 gears. Thanks everyone for the advice and input.
Old Oct 13, 2009 | 04:28 PM
  #23
Z-RATED94's Avatar
Sounds like a plan, let us know how it works out.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
