Just verify bleeding clutch for me?
Old Apr 20, 2006 | 04:24 PM
pHEnomIC's Avatar
I want to run new fluid in my clutch just to make sure theres no air in the system, I have no problems with it but when i bled my brakes, they seemed to work a bit better, so i want to do the clutch as well.
I am very confused because it seems a lot of people have problems with this when searching and there are many different methods.
Will this work or do I have to do anything else:
1- Suck out a bit of fluid from the Master cylinder up top, replace with fresh dot-3
2- Apply clutch pressure, open bleeder valve on the side of the transmission, have a tube on it to watch fluid, then close valve and lift up on pedal, repeat until the fluid is bubble free and the color is good. Keep filling up the mc as needed.
Will this work?
_________________
Old Apr 21, 2006 | 09:58 AM
OBE1 95Z28's Avatar
Re: Just verify bleeding clutch for me?
There's no bleeder valve on the clutch hydraulics.
Old Apr 21, 2006 | 10:26 AM
pHEnomIC's Avatar
Then how do you bleed it?
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
1bad427ls1
Sep 23, 2015 01:12 AM
