jumps when i start try to start the car?
Old Apr 23, 2007 | 02:28 PM
fstenuf's Avatar
Well i had my st rebuilt less than 2k miles ago, i think last summer or the summer before? either way everything was working fine when i put the car away for winter now when i go to start it, it jumps forward on me. So i'm guessing it's either the slave or the master cylinder? anyone else have an idea or this problem before? it could be a busted clutch but if everything was fine when i put it away it makes me think that i'm losing fluid or a bubble in the system?
Thanks!
Old Apr 23, 2007 | 06:45 PM
93v8clone's Avatar
sounds like **** got rusty in there take it out for a ride as long as car will release gears let it work itself back in it happens if ya dont work withem in storage
Old Apr 23, 2007 | 08:01 PM
OBE1 95Z28's Avatar
Check the clutch fluid level to make sure you don't have a leak. Does the pedal travel/pressure feel normal?
Old Apr 23, 2007 | 08:48 PM
fstenuf's Avatar
there is some fluid in there but it's not full by anymeans. And the clutch pedal does feel normal.
Old Apr 24, 2007 | 06:41 AM
matLT1's Avatar
Have you tried starting the car with the transmission in neutral? This may eliminate a couple of things.
Old Apr 24, 2007 | 01:27 PM
fstenuf's Avatar
when i do start the the car in neutral, it won't go into gear.
Old Apr 24, 2007 | 08:30 PM
93v8clone's Avatar
sounds like clutch is stuck or shot
Old Apr 24, 2007 | 09:07 PM
fstenuf's Avatar
**** i sure hope not!
Old Apr 25, 2007 | 03:49 PM
ConElite's Avatar
Thats a give. This is simple. Its going to be one of the following:
1. Your Pressure PLate
2.The Slave
3. The Master Cylinder
It could be a combination of 2 or maybe all three but My money is on the Master or Slave. In any case the Trans is going to have to come down. How old is the Slave and/or Master. I have heard of Pressure plates going bad but its not something you hear about very much. Go down the check list. If your leaking then see where its leaking. Try Bleeding the system.
Old Apr 27, 2007 | 02:27 PM
matLT1's Avatar
If you can't get the tranny to engage in gear with the engine running and the car launchs forward when trying to start I would bet money it is something related to your master or slave cylinder.
It is also possible that your fork is broken, but the bottom line is your clutch isn't disengaging and you need to find out why that is.
I would start by removing the slave cylinder from the bellhousing and inspect it for a damaged fork through the hole. If its okay, then you probably need to replace your master/slave cylinder.
Old Apr 27, 2007 | 03:45 PM
OBE1 95Z28's Avatar
2.The Slave
No need to pull the tranny if the master/slave cylinder is bad. These parts are external to the tranny.
Old May 2, 2007 | 10:38 AM
CJ's Avatar
CJ
Let me know if you figure this out because my car is having exactly the same problems. The last I drove it was around November and it drove fine. Now, If I crank it in gear it drives forward. If I keep it out of gear it wont go in after I fire it up. Clutch petal feels fine(nice and firm), no leaks. I adjusted the master cylinder out a little and It may have gotten a little better but its hard to tell. Im about to pull the slave off now and inspect it and check out the shift fork.
Old May 2, 2007 | 04:41 PM
fstenuf's Avatar
Well i guess mine's in the clutch, so idk what i'm gonna do now...my shop checked everything out and couldn't find anything so idk what's gonna happen to it.
Old May 2, 2007 | 04:52 PM
ulakovic22's Avatar
What did they check? The master/slave or did they drop the tranny and look?
Old May 2, 2007 | 04:53 PM
fstenuf's Avatar
i told em not to drop the tranny, but to check everything else out. The only reason i told them not to was because my friend and i did the clutch in stall and he told me that if it was in the clutch that'd he'd take care of it for me.
